Old 04-05-2011, 06:42 PM
blykins blykins is offline
ARP 1/2" studs get 110 lb-ft with their ARP lube. Be liberal with the lube on the washers and studs both. You want the least resistance possible.
Torque in 3 different stages. I usually go 35 lb-ft in sequence on the first lick, then 70 lb-ft, then finish off at 110.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
