Old 04-05-2011, 08:32 PM
Billpro785 Billpro785 is offline
Default correct voltage ??
Have a dumb question , what should the voltage be on a NAF kit car ? Reason I ask , The gas , volt gauges are inop , headlights dim, with a volt meter get 13 at the battery , but on 7 volts at the fuse panel . Bad ground ? Or is there a voltage regulator somewhere ( like the Chryslers had behind the dash ),
Thanks for any ideas
