04-06-2011, 07:27 AM
NH
That filter as the guys point out is the hard part with the 3/8" lines for the HiPo engines. They are typically $400ish by themselves. Dearborn Tube (Tim Mason) has some nice filters that are similar in appearance and work on the factory bracket. Tim also has the tubes and fittings but I have made those. If you are running a fuel pressure guage you will also need a fuel log with the additional fitting on the back. I have also made those.
