Old 04-06-2011, 08:04 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Not following all that was written, and not knowledgable with NAF cars, but where is the "+" power feed to the fuse panel (and then on to the rest of the car) originating from? Where is the battery located? Is there a master fuse? If there is a main power feed post on the fuse panel, consider disconnecting the current feed line and running a temporary new power feed line and see if that helps. Minimal cost. It should be a good size wire too. Any heating on the original main feed wire when in use? Your main power is not routed thru the ignition switch is it? If I had a wiring diagram it would be helpful to me...Anyone?
SPFWiringDiagrams@Comcast.net
