04-07-2011, 07:26 AM
CT
Not sure whether I asked the question correctly ?
Question:
" When using the air filter top in place of the metal top, is it possible the carb & timing will need to be adjusted due to the additional air, as opposed to air entering only from the sides "
Reply:
" You will not need to adjust your carb just by having an X-stream top on the assembly. Keep in mind, the vehicle will not get more air; it will be able to pull air from directly above eliminating turbulence created above the barrel resulting in better performance. If you have any further questions, please contact Customer Support at 800-858-3333. "
Thanks for writing,
Richard Wotring
Product Specialist
800-858-3333
RichardW@KNFilters.com
