Drive shaft angle for Everett Morrison
I am running the short toploader, 428, with a 5 bar link 9" rear axle. My drive shaft angle is 8 degrees and EM says I need to be between 3 and 5. All mounts were welded in place by EM, so I am confused why the angle does not work. I am using the 24" toploader with all mounts that they suggest and the 5 bar link is set to their specs.
My options are to custom make a trans mount which will lower the trans at the rear and will reduce the drive shaft angle, but this then begins to drop the side pipes so they are no longer parallel to the body. EM does not have any suggestions other than lowering the trans. Any ideas???
