How are you measuring your angle? Also, if your trans bracket that bolts up to your frame rails needs to be dropped a small amount to achieve your desired angle why not put some spacers between the bracket and the frame rails to lower your transmission a little. I would try that first before I started making any bracket.
"Let's roll"
"Be part of Something Good
