Originally Posted by terry mason
I have taken the unit out and will be pulling it apart next week, in checking the set up would you recommend setting it up on the loose side of the specs?
The first thing I'd do is a tear down inspection piece by piece. It's not impossible that the parts going in were out of spec/defective. If everything checks OK, then start thinking about loosening it up some. You won't fix the problem until you find it first. Don't just go throwing parts at it blindly.
