Old 04-10-2011, 03:20 AM
strictlypersonl strictlypersonl is offline
You want to set your car up so that, at the proper ride height, the shock is at roughly mid-stroke. Once you've found the correct shock, the ride height must be adjusted by the spring length and/or rate. Don't change the shock length outside of the first parameter: It will reduce your available wheel travel in one direction or another.
