Thanks Tom. I have that same shock with the same spring as I ordered mine from Aldan using the part numbers in the EM book. My pinion angle is 0 degrees, again based on the EM book. What trans mount are you using?
Where do you have the adjusting nuts (rings) on the shocks set?
Do you have the removable cross member for the trans mount?
