Old 04-10-2011, 10:42 AM
Ron61's Avatar
Ron61 Ron61 is offline
Post
If it is the same remote mount you used before and it never leaked, then I would check the facing on the mount to be sure it hasn't cracked or has some bur in it that is tearing your rubber seal ring on the filters. I always filled my filters and put oil on the rubber ring before screwing them on and I never had a leak of any kind. It sounds as if you have already checked to be sure that the oil exits the filter from the center.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
