The only difference between our cars appears to be the pinion angle as mine is set up at 0 degrees. I will assume that your trans with the shim puts the trans back to what EM designed for. Thanks for your time comparing shocks.
What are you using for tires and wheels and what offsets did you use?
I have the Versailles 9" axle housing so I need to know if the 3.65" offset with the 9.5" rims is what I need to order from Vintage. I will be using 295/50r15's for the rear and 245/60r15's for the front.
Thanks again Tom.
