You need to figure out which direction your clutch fork needs to move. If your slave pushes the fork towards the front of the car, then that passenger side ball stud will work. If your slave pushes/pulls the fork towards the rear, then you will need to use the L-bracket that's included with the bellhousing. It bolts to the driver's side and the clutch fork clips into it.
If you want to post some pictures, I can tell you what you have and what you'll need to do to make it work.
