If you are serious about traction control, then I would recommend to go with an aftermarket adjustable setup.
Originally Posted by Zedn
What is wrong with the GM performance controller and loom kits?
We use the GM Performance Kits exclusively here. We need to modify the looms to suit, but they work out perfectly. Cheapest option and all the parts and loom are OEM quality.
Just keep in mind GM Performance use the latest E67 ECU's in a lot of their Kits. They can be fully programmed by HP Tuners/VCM Suite, but we have heard of problems doing mafless tunes if that is the direction you want to take. The HP Tuners software may be updated enough now to fully support mafless with E67, not something most of our customers worry about.
