Originally Posted by 400TT
The E38 ecu is old and simple. You can easily program it to run MAFLESS as all the Commodore guys do.
So yes, the E38 is an ideal choice for your LS7.
Sorry we just haven't done ABS, Traction or Cruise with the factory GM ECU's so can't help with your other answers.
Hi Craig... what do you mean by old and simple. E38 came out same time as E67... they are basically the same ECU just one does CAN only (E38) and the other does CAN and Serial (E67).
I was under the impression that the reason behind it (E67) was that it was easier for the US to make it backwards compatible with their other internal equipment where as us Aussies installed a translator - may be wrong.
