Old 04-19-2011, 02:10 PM
itsphoenix itsphoenix is offline
Cobra Make, Engine: Superformace, Big Block
Default New owner, please help
I am a proud new owner of a 1999 Superformance and am looking forward to learning allot from you all.
Need help with a gas pedal problem. It has about 3/4" play when depressed before it engages the throttle. It is sticking down just at throttle engagement. It does not appear to be sticking on the shaft to the carb. From time to time I have to lift the throttle from the underside to bring it back up. Reminds me of dead peddle on a bad clutch.
I checked the spring and it seems okay but could it be as simple as replacing the spring or could it be something else?
Thank You
