i dont have a SPF.....but if you have to pull the pedal up with your foot to shut down the throttle then i would start by replaceing the spring......if it is a cable then find a can of cable lube ( motorcycle shops sell it) and lube the heck out of the cable and look for any spots where it may be beginning to frey.....if its mechanical linkage then check for where it may be binding up....broken motor mounts have been known to let the motor rock enough to make the linkage bind while going around corners...
hope this helps......
welcome to CC...
post some pics..
