Originally Posted by Mark IV
Make sure the linkage is not going "over center" on idle throttle. The Superformance has a slot on the arm in the engine compartment that allows control of the amount of trottle "throw". if you have too much it may be oever center and the spring is not strong enough to return to idle posistion. Also check for play in the pivots. There are bushings on the cross shaft that could be worn and allowing the sticking. I can provide a diagram of the trottle system and shows the parts if you need.
A diagram would be great.
Thank you
