Sounds more like a number that the mfgr assigned to the frame/kit. Okla does assign VIN numbers, but as far as I know, they don't require it to be stamped on the right frame rail.
I've got my paperwork sent in right now, and I'm hoping that Okla will use my FFR frame number as my VIN#. Whatever number they assign as my VIN, I will have it engraved onto a small plate and rivet it to my frame, probably next to the FFR# on the frame.
I haven't been much help to you, maybe some others from Okla will reply to you.
Good luck, and congrats on the barn find!
Wideglidejoe
FFR#6143 Mk III: FE 462" w/four 48 IDA Weber's w/TKO 600 .82, IRS w/3.27, 17" Team III's w/245/45's & 315/35's. Gas N's.
Picked it up end of Aug '08
First start May 12, '10
First go kart May 26, '10
Tag & title 5-26-11, driving in gel coat
Painted Nov 2015
'05 Harley Wide Glide (60 hp stock, now 107 hp & 107 ft/lbs at wheel. Mid 11's in the 1/4 mi.)
'55 Bel Air hot rod project (WIP)
