Lower control arm bushings
Installing my front suspension now. The lower control arms ride in poly bushings with no grease fittings, just assembly grease. I have had bad luck with poly bushings in the past in regards to squeaking. Do any of you guys have squeaking down there? Or should I drill and install zerks?
