I thought about that but they act as a check valve and I wasn't sure what effect closing them off would have had.
I went to the track for some testing and it was running rich, actually fouling plugs. I was running a 150 air corrector with a 165 main. I am going to try a 155 or a 160 main. I think that will fix the rich effect.
What was very interesting is that I had 2 spark plugs, 3 and 6, that where dangerously lean at the same time, I fouled 4 and 8. I initially thought that I had debris in the passage ways, choking the fuel supply. After some inspecting, I think it is a result of the hood scoop. It dumps air right into 2,3,6 and 7. I was running the float about a millimeter low on 3 and 6 to correct a casting difference between Spanish and Italian carbs. My guess is that if I put a baffle in the scoop like the 289 cars, this lean condition will go away. (after I re-adjust the floats)
Any thoughts on this?
High Maintenance Racing Team
Run & Gun 2003 - 2013
