Originally Posted by leroy17
I think that this is the way that I will look to go, one of the best options that I have seen that works for me.
Aside from Mikes reverse impeller and custom pulley set up which is awesome what I am looking for dosnt appear to exist. The electric water pump options are a nice looking kit and would achieve what I want and also there are a number of kits and all possible pulley locations and set ups as well.
This will not be solved as quick as I first thought however it has given me ideas on approaching this in a different way to suit what I want to achieve.
Boxhead, asside from less contact area on the crank and alternator, could that idler pulley be deleated.. or am missing something .
As you say, there will be less contact, weather that is detremental, I do not know.
But why do you need to remove the lower pulley?
In the car it is almost out of sight anf in most Cobra's there is plenty of room in that area, that lower idler is the factory one.
I dont think there was anything that would fowl the belt with it removed.
Cruising in 5th
![Whacked](images/smilies/freak6.gif)
