Thread: 460 Leak
Old 04-27-2011, 09:57 PM
itsphoenix itsphoenix is offline
Cobra Make, Engine: Superformace, Big Block
Default 460 Leak
I have a small oil leak. I seams to be leaking at the top of the front plate of the bell housing and running down. I check for leaks around the oil pan and have found none. I also can not see a source point at the bell housing / oil pan area.
Only leaks after running the car, about 3-5 drops of oil. Any thoughts?
Could it be the main seal if its on the front of the bell housing?
Thanks for your help.
