My Best Street Combination is a 1991 (F1TE) 5.0L roller block with a eagle steel 331 crank, nice pistons, I Beam rods, - and 1993 Cobra (GT40) heads, or the SVO aluminum versions -- with an E303 cam indexed 4 degrees advanced.
Roller 1.6 ( or 1.7 rockers ) top off the valvetrain, -with Carb or EFI. this with a regular steel flywheel you can jam pretty good, ---
if you feel you need a little more pop, 1.7 rockers with a F303 cam indexed at 0 ( straight up ) is the good combo.
Steve
