Rick, I had the same problem. Go to a good hardware store (Ace Hardware carries a huge selection of stainless bolts) and get a 1" stainless button head bolt and a stainless lock washer. You may have to remove the hose clamp, but it will squeeze pass the coolant hose. Tighten the bolt with a T handle, ball end, allen wrench. I use a billet steel distributor hold down bracket which is thicker than normal, works like a charm.
Snakebit
