Old 04-30-2011, 01:24 PM
MaSnaka's Avatar
MaSnaka MaSnaka is offline
Cobraman,
I was quoting you measurements from memory...ah today I used my tape measure and came up with different numbers...imagine that, sorry. here are the correct measurements you can use to compare with your own. front wheel well lip at the top is 26", rear is 27", oil pan and bell housing ground clearance 3 1/4". It,s enough clearance for most bumps but I do like DV recommends and pass the taller bumps at as much angle as I can, grit my teeth and squint my eyes and cross my fingers and hope.
John
