The 3/4" foam will take up the engine movements.
You have some kind of box under the hood, Bill. Does the air enter through the top of hood? If so, do you know if this is a high- or a low airpressure zone? I I ask because I'm looking at the option myself.)
I have only 1/2" of softrubber. Although the engine mounts are (hard)rubber, I doubt the enigne will twist or bounce to a very large extent. Last year I got into trouble- the engine was tilted quite an amount. Reason was a broken steel engine mount. Will not happen again.
