Originally Posted by kyleb
What cruise stalk or controls are you using ? My LS1 is DBW and I am also thinking of hooking up the cruise.. I am led to believe all you need to do is connect the wires to the stalk no BCM required...After that cup holders to go in (my wife made me do it).
My LS1 is the cable throttle type that does not interact electronically with the ECU. i.e. the Cruise Control Module is a standalone unit with its own cable that connects in parallel with the existing manual throttle cable.
I think if you have the DBW LS1 then your ECU is different to mine and you use a different approach (with a PIM I think that converts the crsuise control signals to a Serial Bus signal).
Regarding switches I am initially going for a couple of dash mounted switches and LEDs on the right hand side of my steering column.
I am working on another electronic circuit to move the switches to the steering wheel (utilising my Horn button wire).
Rgds
Gregg
