Old 05-05-2011, 09:48 PM
mattpatt's Avatar
mattpatt mattpatt is offline
Cobra Make, Engine: Superformance SP3033, KC SBF 427
Originally Posted by jhv48 View Post
It seems to me that you went kind of skinny on the tires. Most run 315's on the rear with that kind of power.
You will have to be very careful with the gas pedal unless you want to do a lot of sliding around.
I wanted to use the Bridgestone Potenza RE11s but the sizes wouldn't work. Next best, as near as I could tell, was the PS2s. Looking at the Michelyn specs the SP wheel widths worked with the smaller tires (not the 305's or larger) - also - I didn't want to stray too far from factory recommendations because, while real wide rear tires look really great, they probably reduce handling performance (and we could debate about 0-60 performance). If I could have gotten 295's in my tire choice I would have gone for them (a factory option).
