Hi,
Glad you found the problem.
I should mention to check the wires going to your coil. There should only be 1 wire on each side of the coil, a twisted pair from the capacitor in the msd box. Alot of problems can crop up if a 12volt wire is added, like in a standard ignition.
Perry.
