Originally Posted by littlewave
Thanks Cashburn. I was told to use a Mallory series 32 small diameter distributor. Did you try that dist.?, or did you use the normal diameter distributor and just cap the rails?
I have the system on a CAV GT-40. 302 SB (bored and stroked to 363ci). There is no size of distributor that would allow you to loop the rails on the front. Because of the bundle of snakes we had to improvise on the loop in the back.
Comp Cams help line is not particularly helpful.
I'll try to find or take a better photo to show just how tight it is.
