Thread
Bellhousing Alignment, i think i finally got it
4
permalink
05-08-2011, 06:01 PM
RICK LAKE
Here is an easy way to adjust without moving pins
RestoCreations. Here's the easy way to get .010"
Do you have dermel tool? if yes pull the bell housing and run a thin marker line on both pin holes. on the left one you want it at 9:00 oclock outter edge and on the right side 3:00 on the inside. Only go from 10:00 to 8:00. Don't go from top to bottom. The same applys for the right side. from 2:00 to 4:00 oclock on the black of the marker this will give you about .020" to play with. A small drill bit can be used as a file and do the same thing. If you have a round file for steel this will work too. Just remove a little metal should get you on center. Hey, how about a first name. It's better than call you Restro.
Rick L Ps You are way to smart to do this is why you are going nuts. This is when a 5 year old has it simple. Don't rotate the pins any more. leave them alone. Follow the K.I.S.S. theory, Keep it simple SILLY. Don't over think the problem.
RICK LAKE
View Public Profile
Find all posts by RICK LAKE
