Old 05-09-2011, 02:00 AM
750hp's Avatar
750hp 750hp is offline
Thanks for the replies. I'd need to do 16 injectors, so this could get expensive...
Rick, I'd really like a full test on the bench, ramping through pulse width then through fuel pressure ranges, rather than simply measuring flow.
Running 2 injectors per cylinder on a big cube, big boost supercharged deal. Low impedance with EV1 connectors:
8 x 1000cc for the majority of the time
8 x 1600cc for when the wind starts to blow and the floodgates need to open.
Boost referenced fuel pressure under load will be around 70psi, so I need to make sure the injectors are matched at that pressure as well as the default 43.5psi.
I'll make some phone calls and see what the going rate is these days.
Craig
