Originally Posted by trularin
Another common problem is blinker load. If you put LEDs in, they may not load the blinker correctly causing an assortment of problems.
Just a bit more.
Yep there's not enough current to heat the bi-metal strip in the flasher can...there's an electronic unit available now. Most mobs that supply the LED lamps supply the can.
