Gear ratio
Hi,
The 3.07 gears are fine with a TKO-600 if research the cam profile and speed in 5th. Lots of more radical cammed big blocks will need the .82 5th if the RPM is to low for the engine to run properly in 5th gear.
The choice of 5th gear is not a "one-size fits all". The 2 questions to you would be, what camshaft, carb & speed do you want to drive at?
Call me with any questions,
Originally Posted by cobraman428
I am running a FE engine with TKO-600 with 27" tires & rear is 3.08". First gear is 2.87 and is perfectly fine. 5th gear 0.64 is SWEET !!!!
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
