Old 05-16-2011, 06:58 AM
winnipaw winnipaw is offline
Cobra Make, Engine: Backdraft 427 FE 4spd
Default Ford Ignition Cylinder Replacement Problem
I just replaced the ignition key cylinder in my Cobra's FORD steering column. Is there a trick to getting it aligned in the column to get the full action from lock to start? I cant seem to activate each event; lock,ignition,start. If I get the starter to activate and release the key, the ignition cuts out. If I get the column to lock, I cant activate the start sequence. I've taken the brass gear out of the cylinder opening and changed position at least 15 times. I've spent enough hours on it and need to know the installation tricks. Any help out there?
