Old 05-16-2011, 10:41 AM
bobcowan's Avatar
bobcowan bobcowan is offline
The alternater will only produce enough amps to get the job done. If the battery is fresh and there's no other load, the alternater will only produce 10-20A. As lon as the volts are good, don't worry about the amps until you start putting a bigger load on the system.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
