I have a stock fuel injected 5.0 engine.
What is a cost conscious yet safe way to run the lines from the fuel tank to the engine? Fuel pump will be inline and probably be mounted in front of the tank.
I was going to use brake lines with small sections of fuel injection hose but know I am not sure if that is the best approach. I also concerned about finding barbed fittings to connect the brake line to the fuel hose.
Can use hose (like GoodYear Insta-grip) and route it the entire way?
(BTW, I have found out that I am not the best brake line pipe bender.
