Highest CCA you can find in your size
mattpatt Matt unless the batterys is mount other that trminal side upAny battery will do. There are only a couple of battery companies making all the batterys sold. Opti I believe builds their own. If you can find a 750 CCA or higher, this should be fine. Check the warrentty for coverage. First year is free replacement and after that pro rated. Some have a free replacment for 5 years. This battery also cost double the price. I do know that Opti batterys charge higher voltage that other normal ones. This is hard on the Alt and charging system. Would recomend you have a master fuse to protect if a short happens in the car. I have a 95 amp setup and run a volt meter. I run 14.21 volts. I don't worry about amps, they are there. If you can isolate the battery with some hard foam and still have it not move around, this may help extend the life of the battery. I also run a trickel charger. Check batterys at Sears, Pepboys, Auto zone, O'Reillys, NAPA, for prices and warrenttys. Good luck Rick L.
