Old 05-17-2011, 08:40 AM
rustyBob rustyBob is offline
can you post a pic. of what you have.....
if you have the stock lower control arms with the strut rod the the lower arm mounts inside of a channel in the frame...correct
the strut rod eliminator arms mount on the outside of the channel in the frame and you add a longer bolt and a piece of thick wall tubeing on the inside of that channel (weld it in) and then you remove the strut rod....
