Old 05-18-2011, 06:15 AM
Z-linkCobra's Avatar
Z-linkCobra Z-linkCobra is offline
Cobra Make, Engine: Everett Morrison, All aluminum small block ford.
If you must use crimp on terminals use the Weather Pack type. I have had too many failures with crimp on terminals other than Weather Pack. I use solder and heat shrink, unless you break the wire or the terminal itself...the bond will not fail. Make sure you use rosin core solder and pre tin the wires to be soldered.
just my 2 cents
" If it wont break em loose in 3rd gear, it aint enough power "
