Thread
Change of oil and found metallic spring etc inside - need your advise.
13
permalink
05-18-2011, 08:53 AM
cdnus
Cobra Make, Engine: 408w 500 h.p. 550 ft.lbs
Don't be cranking the engine unless you are sure you have
oil
pressure first.
Pull the distributor & use a drill with a
oil
pump drive shaft to check things first. That way there will be no further harm to engine.
Craig
cdnus
View Public Profile
Find all posts by cdnus
