I had a similar problem and I put new gaskets between the flange and the head, as mentioned above, then I spread Permatex Hi-Temp Copper on the pipes where the slip fit takes place. Problem solved. Keep a watch on how tight the header bolts are. If they loosen and begin to leak, the problem invariably worsens.
When I said I wanted to be somebody, I probably should have been more specific...
