This was not a lifter failure!!!!! How could it be? The root of this problem is what allowed the circlip to popout of the lifter allowing it to come apart. #1 the valve lash was set to close to zero and there was slop between the pushrod and lifter cup causing excessive vibration causing the circlip to pop or break. #2 You bent a pushrod or a bent one was installed. #3 you floated the valves.
Ford racing lifters are perfectly fine, they live in millions of 5.0L for 200K miles. Nobody can match that track record.
