Once the lifter is installed and the valve lash set correctly YOU COULD REMOVE THE CIRCLIP. It should never see any load if it has .030 preload on it. UNLESS, bent pushrod, very unlikely, or incorrect valve adjustment from the get go, my bet. Hey if it is the first valve on either side that would be my guess since it goes from intake on pass to exhaust on driver. You need to know this when you set the lash.
