Yep, been through this too. Didn't notice it until car was assembled with freshly coated ceramic sidepipes. Mine leaked at the sidepipe where the 4 pipes reduced to one at the collector. I removed the sidepipe from the car. Stood the sidepipe vertically and took some masking tape to prevent leakage and used the orange high temp gasket maker and filled the cavity. I had to use a piece of 1/4" tubing about 8 inches long to extend the nozel to feed down through the collector. I heated the tube of gasket maker so it flowed freely and filled in the cavity. No leaks for several years now. I did not want to deal with taking it to welder and risking screwing up the freshly ceramic coated pipe. Fixed for about $3.99 !!!!!
