Originally Posted by andronikos916
How can I check what cylinder heads I have?
Engine builder should have that info, also,I would ask if there were any modifications to the heads from new....There should also be name/numbers between the rocker studs and the name on the outside ends of each cylinder head, that may be hard to see with the accesories though...
I can understand you wanting to do the work yourself,it's rewarding to say you did it and the only way to learn, but I would suggest at least have an expirenced mechanic help you check things out and be there for the re-assembly....not doing something correctly becasue you just didn't know how to do it could be costly....been there,done that......
Putting the distributor back in is not hard,just have to follow certain procedures to get it right........
take the two rockers arms that had broken studs, then them over and look for marks where they could have hit the valve spring retainer...wipe them clean and look good or post pictures......
David
