  #74 (permalink)
Old 05-24-2011, 04:11 AM
andronikos916 andronikos916 is offline
Thank you guys. I am going now to the mechanic to do the following:
- Collect all broken parts, to check if there are any missing.
- Check the damaged push-rods if are bended
- Check the lifter adjustment (preload) on another lifter
- Do the oil drain check for possible damage on valves or pistons
- Drop pan inspect rods and crank
What is the "correct" valve geometry? What I need to check?
Best - Andronikos.
