Originally Posted by John Nomeyko
when you mounted the cans did you use the bracket dennis sent and if so did you drill two holes or four in the fire wall?
John,
I drilled 2 holes on either side of the rivet located on the firewall. There is a 2" x 1" square tube behind the firewall in that location. You can locate the cans in the center of the firewall but do make sure you leave enough clearance for your throttle linkage. I made sure there was 1/2" between the closest canister and the linkage assembly.
Take care when drilling as the heater core is just beyond that tube!
