I'm curious about the engine builder's response also. In the mean time, take the
oil pump out and see if you can turn it by hand. With no
oil in it you should be able to turn it. Open it up and inspect the impeller looking for any debrise that could have caused it to seize. I also feel that you did nothing wrong to cause this problem other than buying a car with a problem engine. You are not to blame.
